05-12-2021 05:11 AM
Our network runs cucm 11.5 on 2 BE7000 UCS boxes. The following services/vms are shared among the two BE7Ks:
UCS 1
UCS 2
Do I simply buy a smartnet contract for the 2 USC blades to get support for all these services plus the BE Hardware? OR do I have to account for the serial numbers of each of the VMs deployed in addition to the UCS hardware?
Solved! Go to Solution.
05-12-2021 06:47 AM - edited 05-12-2021 07:03 AM
Smartnet cover hardware, you will be able to replace the hardware if faulty and download firmware for your ucs.
software subscription (SWSS) cover the software including VMware(if VMware was a part of the order).With valid SWSS you can upgrade VMware and UC application.
When you upgrade to major version for example 10 to 11 or 12, version 10 license will not work on 11 or 12. So with SWSS you can request upgrade licenses through MCE portal.
Freenas will not be a part of it.
05-12-2021 07:25 AM
Dear Nithin,
Thank you very much for the clarification. Your answer has cleared out most of the fog.
So, as I understand it, to get full cover, I need both the Smartnet (for the hardware) and the sofware subscription (for the applications).
Could you kindly advise on the part numbers for these two?
05-12-2021 07:50 AM
To get full coverage you need Smartnet and SWSS. The license model has changed from perpetual to FLEX(Subscription). last date to attach a new contact is January 23, 2022. You can consider migrating to Flex license model. Even if you are not migrating within two years perpetual licensing will reach EOL.
If you are a Cisco partner, with old contractor or SO or Serial you can generate the quote from CCWR . if not a partner Its recommended to contact local Cisco Partner who supplied it or Local Cisco Service AM. They will provide you the BOQ with all part numbers if any part number has reached EOL they need to consider the new. Renewal is a different process.
