CUCMBE migration using 3&3 advanced messenging option
vecarpen
I am ordering an upgrade from 6.0 to 8.0 using the 3&3 promotion program.
This is a Business Edition system.
I think I have everything figure out except there is a messenging option that will add advanced user feature for things like IMAP and TTS.
The customer paid for this on the original 6.0 system, so I would think it would transfer.  Would I need to select this item in the Dynamic Configuration Tool or will it get transfered over when the migration is done.
Last thing I Need to know to finish the order.
Thanks.
skilambi
If you are using this program means they have no support to begin with. If they had UCSS what they paid for would move forward. Since their support has lapsed and hence you are using the 3x3 program you have to select this option separately unless you go to CUWL BE.
http://www.cisco.com/web/partners/downloads/partner/WWChannels/technology/ipc/downloads/ip_comm_ucl_og.pdf
See Page 8, you need the Advanced User Option
UNITYCN8-ADV-USR
Srini
