CUE AA redirect to external call not disconnecting
Marc El Achkar
I have a problem with cue AA redirect to external number not disconnecting only when the external number does not answer; if the external number redirected to does answer, the lines disconnects normally.
My FXO config is as below for all the lines:
voice-port 0/0/0
 trunk-group AllFXO
 supervisory disconnect dualtone mid-call
 input gain 3
 output attenuation -1
 echo-cancel coverage 32
 cptone KW
 timeouts initial 5
 timeouts interdigit 3
 timeouts call-disconnect 3
 timeouts ringing 5
 timeouts wait-release 1
 connection plar 665
 impedance complex2
 caller-id enable
Hello Did you get to the bottom of this issue I have a similar problem.
If you are trying to do a FXO to FXO hairpin, add the following command and then test -
voice-card 0
no local-bypass
voice-card is your PVDM. The numeric is the slot which holds this card.
