CUE Licenses question
coffee
Hello Everyone,
I have an ISM-SRE-300-K9 module on a 2921 running CUE 8.5.1. I'm nearing what I believe(d?) is our
voice mailbox limit of 50. In CUE when I take a look at our licenses (administration>licenses), I see this below:licenses.PNG                                       I see there are two entries for Permanent licenses that are inactive for a total of 65. Does this indicate that I have 65 more licenses installed that just need to be activated? I've also included my sh license all result below:
License Store: Primary License Storage
StoreIndex: 0 Feature: ipbasek9 Version: 1.0
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
StoreIndex: 1 Feature: uck9 Version: 1.0
StoreIndex: 2 Feature: securityk9 Version: 1.0
StoreIndex: 3 Feature: VMIVR-VM-MBX Version: 1.0
License State: Active, Not in Use
License Count: 15/0/0 (Active/In-use/Violation)
License Store: Built-In License Storage
StoreIndex: 0 Feature: securityk9 Version: 1.0
License Type: EvalRightToUse
License State: Inactive
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 4 days
Period used: 0 minute 0 second
License Priority: None
StoreIndex: 2 Feature: datak9 Version: 1.0
License State: Active, Not in Use, EULA not accepted
StoreIndex: 3 Feature: FoundationSuiteK9 Version: 1.0
StoreIndex: 4 Feature: AdvUCSuiteK9 Version: 1.0
StoreIndex: 5 Feature: ios-ips-update Version: 1.0
StoreIndex: 6 Feature: SNASw Version: 1.0
StoreIndex: 7 Feature: cme-srst Version: 1.0
License Type: RightToUse
License Count: 115/0 (In-use/Violation)
License Priority: Low
Vaijanath Sonvane
Cisco Unity Express on ISM-SRE-300-K9 supports maximum 100 voicemail licenses:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/rel8_5/rel_notes/rel_notes85.html
So, in your case you can activate 50 more voicemail licenses on CUE.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Hello and Thank you for your reply.
I have just another question. Am I wrong to believe that the 50 more voicemail licenses that I can activate on
my device have already been installed and are just inactive or would I need to purchase 50 more and get those installed?
(sorry if this is a bit redundant, I'm kind of new to this)
