CUMA and MCS-7825I4-K9-IPC1, ask for drivers
francisg
trying to install Mobility Advantage 7.x on a MCS-7825I4-IPC1 server.  After asking for localization infor (country, language etc), I get an error "no device found".  What driver do I need?  Do I need to download a specific driver?
It's "supposed" to be non-bootable.  But please try it.  You might be surprised.
BTW, this kind of issue cannot be solved by "two-stage" upgrade, because it failed at the very first beginning.  You won't even get to the part that asking you if you want to apply a patch.
Michael
6 Replies 6
Those are non-bootable DVD ISO.  What can I use to boot the server?
thanks.
If I recall correctly, 7.x of CUMA has the same install routine/OS as CallManager... if that is the case, then did you see prompt during install along the lines of 'Do you want to install a patch as part of this upgrade'?
If you did see that you should be able to answer yes and point the server at the downloaded file on an SFTP server...
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Michael
charl
Just wondered if you managed to get this working and what the resolution was as I am facing the same issue now.
thanks
Charl
download the non-bootable ISO cuma 7.1(3) installer from CCO.  Try to use the non-bootable ISO to boot server.
