CUPC Client stuck on invisible/offline
Scott Brien
Hi all,
We have a CUPS integration with CUCM, however none of our CUPC can change to an online state.
when a user changes state to online the state does not change.
also presence viewer also states that other users can see the user as available until they log in and cannot see the user online the presence viewer test then says that they are unavailable.
Deskphone calling is working correctly.
Logon Server, Precense Desk Phone, Voicemail and LDAP are all connected and succesful.
connection down bottom of CUPC is connected.
Has anyone experienced anything similar to this? Any help would be appreciated.
Scott
25 Replies 25
Could you attached the packet capture from client and server side?
Thanks!
Michael
Hi Michael,
It seems that we are only receiving SIP NOTIFY packets intermittently.
Have you seen anything similar to this before? There is nothing in our infrastructure denying these packets.
Scott
The proof is very obvious -
We have server capture and client capture.  From server capture, we can see NOTIFY bening sent.  From client capture, we don't see it.
If a packet left its source but didn't arrive on destination, what could it be?
I cannot tell you where the problem is.  But I can tell you the problem is not on CUPS/CUPC.
Michael
http://htluo.blogspot.com
Hi Michael,
Are there any specific commands on the ASA55XX series which would be dropping specific SIP packets other than security policies specifying to do this.
We have SIP inspection enabled, but no ACLS or policies specifying for this to be blocked.
Scott
You may try to turn off SIP Inspection on ASA.  I think it's on by default.
Michael
Hi Michael,
Please see capture files attached of CUPC changing status with notify packets being received.
status changes from away to available which switches to offline and from offline to away and so on.
Cheers,
Scott
If you looked at CUPS_CLIENT.pcap, you'll see that those NOTIFY was from the client to the server.
What we are missing is the NOTIFY from the server.
It's still the same problem as before.
Michael
Hi Michael,
Disabling the SIP inspections resolved this issue.
Thanks for your help.
Very useful.
Scott
Note: when status change takes place packet captures are showing TCP reset packets.
Scott
sfariasfboc
This is happening to us also
I have unassigned users and
then reassign them and it seems to work some of the time but why they go invisible after awhile still baffles me
Has anyone seen where a users working for a week then not
This issue was caused by SIP inspection on FWSM dropping the packets between CUPS and CUCM
Maybe try that.
Scott
