CUPC missing users
john katsavras
Hi there,
We are running CUPC ver 8.6.1.10000-34 that is integrated with LDAP
For some reason for a very few users when we search for them using the "Search Directory" using either there first name or surname they cannot be found. If we search for them using there NT User ID then that works.
Anyone have any suggestions on how to troubleshoot this?
Alexis
http://www.netpacket.co.uk/ http://www.blog.netpacket.co.uk/
What I would do is to take a sniffer capture from the PC while performing a search for the users in question.
Unless the connection to LDAP is secure, you will be able to see the query you send out to AD and what you get as a reply.
HTH,
Christos
HTH,
Christos
Hi there,
Just to let people know in case they have the same issue.
This was not a CUPC issue but AD was timing out due to its size. Only effected some users due to the index used for searching hence why user ID worked but first name and surname didn't
Alexis
