CUPS Ver 10.5.1 Error in installation
Hi ,
I am trying to install Cisco CUPS and I always get Error in installation stage as per attachment.
is there any solution,
Ahmed
The output looks good. Do below:
Delete the entry of IM&P server from CM >> System >> Server
Restart the CM server
Add the entry back again of IM&P server
Deploy the VM again and change the Network Adapter setting and then proceed with the installation. If it fails again, collect the dump/diagnostic logs. Refer to below document for this::
http://docwiki.cisco.com/wiki/How_to_Dump_Install_Logs_to_the_Serial_Port_of_the_Virtual_Machine
In case, if you have already collected the dump logs then provide the same before performing the workaround that I mentioned above. Also, I hope you are entering the correct Security Password during the IM&P installation, it should exactly the same as on CUCM Pub
Deepak
11 Replies 11
Jaime Valencia
Is this the first IM&P in the cluster??
Have all the steps in CUCM been taken care of??
What OVA are you using??
You'd need to look at the diagnostic logs to pinpoint the issue.
java
if this helps, please rate
Its Standalone installation .
For The CUCM I add the CUPS IP Details in as adding Subscriber
I am using the Ova cucm_im_p_10.5_vmv8_v1.0 for 500 Users.
Provide the below outputs from CUCM Publisher CLI:
show version
run sql select userid,enablecups from enduser where enablecups='t'
run sql select count(*) from enduser where enablecups='t'
Also be aware of below defect and make sure the network adapter type is changed to VMXNET 3 manually right after you deploy the OVA and before starting the installation
https://tools.cisco.com/bugsearch/bug/CSCur69305/?reffering_site=dumpcr
Deepak
Hello Deepak,
Thank you for your answer, but i tired that also and I got an error as per the attachment.
Provide the above mentioned outputs from CUCM pub
Deepak
Hi Deepak,
Please find out the Outputs in attachment
Ahmed
What about the output of show version active, need to know the exact CM version
Show Version Active in attachment
Ahmed
Deepak
Hello Deepak.
Thank you for your support ,,
I install CUPS successfully ..I did report the CUCM PUB and I change the IP while I am installing as well.
Thanks for your great answer and support.
Ahmed
Glad issue had been resolved Ahmed and thanks for updating the forum.
Deepak
