Decommission Unity Connection Node
I have a Unity Connection cluster with 1 Subscriber. I would like to decommission one of the nodes due to a corruption in the database which is causing a constant split brain scenario. Is there a procedure to follow to properly decommission the node?
Chris Deren
You can follow the procedure for Replacing a Subscriber Server from the document to demote the subscriber from the cluster.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/12x/install_upgrade/guide/b_12xcuciumg/b_12xcuciumg_chapter_0100.html#ID-2164-00000096
