Device Assocation , is there an easier way?
jalsman
I've got over 1000 devices in call manager and I need to associate each one of those to a respecitive user. All users are synchronized with AD. Is there any way to automate this process?
Chris Deren
Yes, you can use bulk "Update Users".
Chris
is this the same thing as the BAT tool?
Correct, in the user file include the device you need to associate with the user, the file can look like this:
USER ID,PASSWORD,MANAGER USER ID,DEPARTMENT,PIN,DEFAULT PROFILE,USER LOCALE,TELEPHONE NUMBER,PRIMARY EXTENSION,ASSOCIATED PC,IPCC EXTENSION,MAIL ID,USER GROUP 1,CONTROLLED PROFILE 1,CONTROLLED DEVICE 1
chris,,,,,,,3000,3000,,3000,,,,SEP0011BB65BD6B
then simply upload the file as a user/update user file, go to Bulk Administration-->Users-->Update Users
HTH,
Chris
