Dial Peer Group using provision policy
Paul Austin
Level 4
Level 4
Hi All, Trying to understand provisioning and DPG config. Basically what I want to do is to use DPG's to send calls to a specific outbound dial-peer but use the inbound VIA field (IP address) to use the DPG config. Does anyone have any sample configs that I can use? I have had a look but I'm just not understanding the docs.
This is an example of a configuration that should fit what you ask about.
voice class uri SME sip
 host ipv4:<SME CM 1 IP>
 host ipv4:<SME CM 2 IP>
voice class dpg 1
 dial-peer 401
dial-peer voice 1 voip
 description Incoming Dial-Peer from SME
 translation-profile incoming To_Webex_IN
 session protocol sipv2
 session transport udp
 destination dpg 1
 incoming uri via SME
 voice-class codec 4
 voice-class sip bind control source-interface Port-channel32
 voice-class sip bind media source-interface Port-channel32
 dtmf-relay rtp-nte sip-kpml
 no vad
dial-peer voice 401 voip
 description Outbound Dial-Peer for calls to Webex CME
 session target dns:eccce.emea.pub.webex.com
 destination e164-pattern-map 4
 voice-class codec 4
 voice-class sip early-offer forced
 voice-class sip options-keepalive up-interval 15 down-interval 5
 voice-class sip bind control source-interface Loopback0
 voice-class sip bind media source-interface Loopback0
 dtmf-relay rtp-nte
 no vad
Response Signature
voice class dpg 1
 dial-peer 401
 destination dpg 1
 voice-class codec 4
 no vad
 voice-class codec 4
 dtmf-relay rtp-nte
 no vad
Response Signature
Paul Austin
Level 4
Level 4
That looks spot on - many thanks
