Dial-rule question
mamkreutz01
Again the CME 4.1 system. We use some Nokia phones in conjunction with this system. Our nokia users in the netherlands program their phone numbers as following:
0031612345678
Or
0031201234567
What is the best way to create an outgoing dial rule for this so that when somebody puts this in the outcome would be:
0612345678
Or:
0201234567
Thanks in advance.
sorry, i missed you are using CME
configure the following pots dial peer:
destination-pattern 003..........
prefix 0
7 Replies 7
okuehn
Hi Maarten,
configure the following rule:
0031.XXXXXXXXX
discard digits pre dot
prefix 0
the outcome for your example 0031612345678 would be 0612345678
so long, oliver
Hi there,
Thanks for you quick reply. I guess i will use a dial-peer voice pots for it. I can define the destination-pattern but i do not have the command discard digits. I can only use digit-strip but there i cannot put the pre dot command. I can use the prefix command. Any idea how to do this ?
prefix 0
Thanks for the fast reply. How does the system now with this destination-pattern that 003 has to be stripped and that an zero has to be added ? Prefix 0 means the system puts an 0 extra to it ?
that's how dial-peer commands are working.
deletes all digits explicitly matches, and the prefix command add 0
for further readings see http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/srnd/design/guide/gatewy.html
"Dial peer commands are useful if only small changes to the beginning or end of the dialed number are necessary, such as prefixing an area code, prefixing a CO designator (NXX) to an extension number, or forwarding only the last four digits of a longer number. The wildcard matching within the destination-pattern command automatically deletes the numbers explicitly matched."
hope this helps, if so please rate.
Oliver
Hi there oliver,
There is no need for an forward-digits command in this dial-peer ?
no, forward-digits is an optional command.
you might use it only if you want to strip digits based on fix length (beginning from right)
