Différence BE6K-UWL-CM2BE
Ilyasseatbane
Hello ,
Can you please tell me what's the difference between this SKUs :
     - BE6K-UWL-CM2BE ENH to UWL STD without application
     - BE6K-UWL-CMAPPS2BE with application.
Thank you for reponse.
Best regards.
adnan.alim
Level 5
Level 5
Both the Part codes are for License feature upgrades in BE6K Solution. (Upgrade existing UCL licenses to a more advanced entitlement or to CUWL)
If the existing setup is having UCL Enhanced license with out Voicemail license, then to upgrade those Enhanced licenses, use the first SKU...
BE6K-UWL-CM2BE --> Upgrade existing Enhanced license on BE6000 without Voicemail to CUWL Standard
If the existing setup is having UCL Enhanced license with Voicemail license, then to upgrade those Enhanced licenses to CUWL, use the second SKU...
BE6K-UWL-CMAPPS2BE --> Upgrade Enhanced license on BE6000 with Voicemail to CUWL Standard
Hope it clarifies your query...
Ahamed Adnan
