Difference between C8300-1N1S-6T vs C8300-1N1S-6T-V
ednarvaez
Hello community
Excuse me, could you help me with the difference between C8300-1N1S-6T vs C8300-1N1S-6T-V? I can't find information about C8300-1N1S-6T-V.
I would like to know if I can configure HA between 2 C8300-1N1S-6T-V devices?
Thanks for the help
2 Accepted Solutions
The -V means that it’s a voice bundle. It’s literally the exact same router, just with additional modules preselected in the BoM.
Response Signature
You can setup Cube HA on it as it’s the same type of router as the one without the -V.
Response Signature
9 Replies 9
Hello @ednarvaez ,
the C8300-1N1S-6T-V is a C8300-1N1S-6T bundled with a NIM-PVDM-3, so basically the same router with some extra PVDM for voice processing.
If by HA you mean a gateway redundancy protocol like HSRP or VRRP, the answer is yes. Please see the link for details https://www.cisco.com/c/en/us/td/docs/routers/ios/config/17-x/ntw-servs/b-network-services/m_fhp-hsrp-mgo.html
Regards, LG
*** Please Rate All Helpful Responses ***
Oh sorry, by HA I meant Cisco CUBE High Availability
Like the following link:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voi-cube-high-availability-ISR4K.html
I see that the following models are compatible but I would like to confirm it
Thank you
Response Signature
Response Signature
ednarvaez
Thank you for your help
AFAIK, C8300-1N1S-6T-V give you NIM-PVDM-32 included in the Bundle.
Response Signature
ednarvaez
Hi community
Me again sorry,
Can I use the router C8300-1N1S-6T-V how a Local Gateway for a Webex Calling deployment?
Thank you a lot
Yes with the appropriate licensing it would work.
Response Signature
Excellent
Thank you Roger
