- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-05-2025 12:28 PM
Hello community
Excuse me, could you help me with the difference between C8300-1N1S-6T vs C8300-1N1S-6T-V? I can't find information about C8300-1N1S-6T-V.
I would like to know if I can configure HA between 2 C8300-1N1S-6T-V devices?
Thanks for the help
Solved! Go to Solution.
- Labels:
Voice Gateways
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-05-2025 01:23 PM
The -V means that it’s a voice bundle. It’s literally the exact same router, just with additional modules preselected in the BoM.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-05-2025 09:39 PM - edited 03-05-2025 10:47 PM
You can setup Cube HA on it as it’s the same type of router as the one without the -V.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-05-2025 01:18 PM
Hello @ednarvaez ,
the C8300-1N1S-6T-V is a C8300-1N1S-6T bundled with a NIM-PVDM-3, so basically the same router with some extra PVDM for voice processing.
If by HA you mean a gateway redundancy protocol like HSRP or VRRP, the answer is yes. Please see the link for details https://www.cisco.com/c/en/us/td/docs/routers/ios/config/17-x/ntw-servs/b-network-services/m_fhp-hsrp-mgo.html
*** Please Rate All Helpful Responses ***
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-05-2025 01:34 PM
Oh sorry, by HA I meant Cisco CUBE High Availability
Like the following link:
I see that the following models are compatible but I would like to confirm it
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-05-2025 01:23 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-07-2025 04:47 PM
Thank you for your help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-08-2025 10:22 PM
AFAIK, C8300-1N1S-6T-V give you NIM-PVDM-32 included in the Bundle.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-13-2025 04:50 PM
Hi community
Me again sorry,
Can I use the router C8300-1N1S-6T-V how a Local Gateway for a Webex Calling deployment?
Thank you a lot
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-13-2025 10:49 PM
Yes with the appropriate licensing it would work.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-14-2025 09:08 AM
Excellent
Thank you Roger
