Displaying call entering during call
acastilloh5690
Hi, how can I configure a phone with Call Manager in a way that if I pick up a call and another enters, it is displayed in the phone display.
Jaime Valencia
As long as that call is below the busy trigger, it will show.
java
if this helps, please rate
Vaijanath Sonvane
I hope I am understanding your post correctly. If someone does Barge/cBarge on shared line and enters the call, you want to see to/from text display. In this case make sure users are entering the call using "Barge" with Built-In Bridge functionality. Here is the difference between Barge with Buillt-In Bridge and cBarge with Shared Conference:
Here is the URL for configuration:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/12_0_1/featureConfig/cucm_b_cucm-feature-configuration-guide_1201/cucm_b_cucm-feature-configuration-guide_1201_chapter_0100100.html
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
