02-21-2018 04:55 AM - edited 03-19-2019 01:09 PM
Hi Guys,
My Customer is trying to do conference, but, the conference didn´t worked. I verified in the RTMT that appear de Code:
458752 0x70000 |
Drop any party/drop last party
458752 0x70000 Conference drop any party/Conference drop last party (was 128)
I researched about forum, found the code, but not explain the significate about this and what is the root cause of conference no work. Any have idea about this?
I used the link to reference:
Wilson
02-22-2018 02:46 PM
Hi @wilsonsant
first of all ... please check the following:
1) What Conference resource are you using (Hardware/Software)?
2) The Conference is registered?
3) Check if the correct MRGL is used (MRGL > MRG > Conference)?
4) If all the itens above are OK, then try to reset the Media Streaming service?
Hope this helps,
Marcelo Morais
02-23-2018 04:17 AM
Hi Marcelo,
Thanks a lot for Your contact. Answering Your questions
1) the remote site is using conference CUCM (Software)
2) The conference is registered
3) It´s Ok
4) The reset was did, but, didn´t worked
Wilson
02-23-2018 08:20 AM
Hi @wilsonsant
let us know check the details:
1) Are you having problems with every Conferences? If the answer is no, then described the differences.
2) Could you be more specific about "the conference didn't work", for example: A calls B, A clicks the Conference button and calls C, A talks to C, A click the Conference button again, and the Conference starts with A, B and C.
Best regards,
Marcelo Morais
02-23-2018 12:43 PM
Hi Marcelo,
The termination code that I mentioned the title occured when User A call User B, then extended for User C the call dropped. The site is using resource about CUCM (not is local resources)
Wilson
02-23-2018 01:03 PM
Hi @wilsonsant,
in other words, A and B are in the same location, but C is in another one, if my understanding is correct, then:
1. Check for any restrictions between the Conference resource (for A and B) and C, like Codec, CAC, ...
2. Double check A, B and C configuration, for example: What happen when A calls C? What happen when C calls A and try a conference with A and B?
Hope this helps,
Marcelo Morais
