DUCs V.1.2.2 Client Very Slow to load VoiceMail
palves
Hi All,
I've just installed a new Unity Domino unified messaging server. For some reason, when opening a voicemail, it takes 10-15 seconds to open the email (it plays right away when the email finally opens and the media player comes up). This is not normal since a user can open a 5-10 Mbyte file in 1 or 2 seconds. Normal .wav files don't take that long either. Also, even on clients without DUC installed yet, it still takes just as long (any voicemail takes a long time).
I find this a little strange since the voicemail files are stored in the Domino Mail Store (right??).
Anyone experience similar issues?
thanks,
Paul
7 Replies 7
jpattishall
We had the same problem when we allowed the DUCS install to create the template. If you manually add the template items to your mailfile, you may have better luck.
Any idea how to do this?? I recall that option, but I'm not certain how to do this.
thanks,
Paul
We're using DUC 1.2.2 with Notes 6.5 environment, we never leaved DUC installer to update our own template. It causes a lot of trouble, especially if you're also using iNotes. In order to update the templates manualy, you have to 'right-click' on you maulfile icone and do a Database -> Replace Design. as the template server choose the one where your mailfile is installed (should be the same as the DUC server) and choose the option "Show advanced Template" then check the list internaly we 're using the templacte UC iNotes Mail R6 Blue (UCInotesR6Blue.ntf). You should be all set.
PO
pgregory
Hi Paul,
When you install DUCS there is a DLL called ucres_enu.dll that gets created in the Lotus Notes client folder (C:\Program Files\Lotus\Notes by default). There is an issue in that this is a US English resource.
If you are using a localised version of Notes/DUVS then the DUCS client will attempt to open a localised version of that DLL resource. If it's a UK english implementation then simply copy ucres_enu.dll to ucres_eng.dll and and your voice form should open properly. If it's another language then you'll need to use something like sys internals filemon utility to figure out the filename that the app is trying to find.
This is a bug; it's acknowledged in the the DUCS 1.2.2 release notes.
Paul Gregory
I would like to add those infos about the localised version of Notes. In fact you have to duplicate and rename (if you want to be able to switch the regional settings in Windows parameters for the language) the ucres_XXX.dll to the following file according the language. you'll find below the details:
For
BPortuguese
ptb so it will give ucres_ptb.dll
Dutch
nld so it will give ucres_nld.dll
French
fra so it will give ucres_fra.dll
German
deu so it will give ucres_deu.dll
Italian
ita so it will give ucres_ita.dll
Spanish
esn so it will give ucres_esn.dll
TChinese
cht so it will give ucres_cht.dll
SChinese
chs so it will give ucres_chs.dll
Japanese
jpn so it will give ucres_jpn.dll
Korean
kor so it will give ucres_kor.dll
The big issue with DUC is also that this software can't be installed on a ghost (or we did not find how), which is a pain if you have to deploy a lot of clients... If some of you have ideas they're welcome ! :-)
PO
thanks for all the feedback.
I believe it may actually be the anti virus software on the Computers. When it's disabled it appears to be fine.
I have some more testing to do, but it looks promissing.
Yes it is the virus scanner. Just set the scanner to ignore .wav files.
