dx650 default pin/password section removal
Amit23
Level 4
Level 4
is ir possible to disable the pin/password option rhat comes on dx650 when first login and also when phone locks after some time? it ask every time login and it not accepted by clietnts. how can remove so that phone work without pin/password..?
Warm Regard's
Amit Sahrma
Terry Cheema
Check the similar link to see if it helps:
https://supportforums.cisco.com/discussion/12273181/dx650-disable-screen-lock
-Terry
Please rate all helpful posts and mark the thread as answered if you have no other queries.
