04-10-2013 05:03 AM - edited 03-19-2019 06:34 AM
Hello all,
Is Emergency Responder compatible with Business Edition 5000? Version 8.6 for both. It's not specifically mentioned in the CER 8.6 Release notes.
thank you.
Pat
Solved! Go to Solution.
04-10-2013 08:15 AM
The BU never tested this, so it's not officially supported.
It *should* work
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
04-10-2013 08:15 AM
It *should* work
java
04-10-2013 11:08 AM
thanks java! Not what I wanted to hear but appreciate the timely response.
pat
