Emergency Responder and Business Edition 5000
patrickscully
Hello all,
Is Emergency Responder compatible with Business Edition 5000?  Version 8.6 for both.  It's not specifically mentioned in the CER 8.6 Release notes.
thank you.
Pat
Jaime Valencia
The BU never tested this, so it's not officially supported.
It *should* work
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
It *should* work
java
java
thanks java!  Not what I wanted to hear but appreciate the timely response.
pat
