export devices
fk24
hello,
i exported some devices, specifically turret trading, and the file is in .txt format .
when i try to import it into a new call manager , it's impossible. i think it's due to the format .i tried exporting phones using the specific detail and all detail options , and both are in . txt format. do you have any idea how i can import them into the new call manager without errors?
thank you ,
you must use "cucm bulk administration"
for bulk export, import purposes..
see this links + do google search for PDF's & Video's..
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/bat/15/cucm_b_bulk-administration-guide-15/cucm_b_bulk-administration-guide-1251su2_chapter_01.html
https://www.youtube.com/watch?v=a52zxo6A5xs
after seeing those, ask your questions here..
we are glad to help..
(Rate by "Helpful" or "Accept") (محمدرضا هادی_ایران) (Email: morez.hadi@gmail.com)
If the source and destination CUCM clusters are running different versions you will also need to review the column headers. Sometimes newer versions add a column. If that happens, you will need modify the CSV to include that the column and an acceptable value.
