ExpressWay-E certificates
Tieken Maas
Hello everyone,
I'm a bit puzzled as to the following point. Initially, we deployed Expressway-C and -E nodes and used "grey" certificates for the traversal zone. We installed a Windows 2008 based CA, with a self-singned root certificate, and server certificates for both -C and -E nodes were issued using this CA. The traversal zone is ok.
Now the customer would like to use a public "white" certificate for -E node so that WebRTC clients don't receive a warning about a non-reliable certificate. The question is whether we can upload one more server certificate (signed by a public CA like Let's Encrypt) to -E node or not? Won't it disrupt the traversal zone?
ExpressWay version is 8.11.4
Tieken
Jaime Valencia
No, you can only have one server certificate on the expressways, you'll need to generate a new CSR from EXP-E or your own from openssl (or any other tool you like), have it signed, and upload it.
If I recall correctly, it does call for a reboot so services can start using the new certificate.
If you keep the trust chain and the same CN/SAN there should be no problem with your traversal zone.
java
if this helps, please rate
