Expressway is refusing admin/other connections
cb12345678
Hi everyone,
I have vMotioned an Expressway to a new host and restarted it - now although I can ping it, it is refusing HTTPS and SSH (and other connections). I can access the console via vCenter and I can login to the CLI.
by the way, i have checked and this is not a firewall issue. The Expressway itself is refusing the connections.
Can anyone recommend how I can troubleshoot this issue via the console CLI?
thankyou very much!
Jaime Valencia
What version is this??
java
if this helps, please rate
I'm encountering the same problem, after upgrade to version 8.10 (was 8.9.1).
I'm able to perfomr sshd start, but trying the sshd restart, says ssh not running.
The box answers and can send ping.
fortvald
Dennis Mink
so did this work before you vmotioned it?  did anything else change?
Please remember to rate useful posts, by clicking on the stars below.
devils_advocate
Level 7
Level 7
I realise its not ideal but have you tried a forced reboot in VCentre?
