01-15-2023 04:06 PM
Hello guys,
I'm newbie on Expressway and I want to setup a demonstration platform, I already installed both expressway-c and expressway-e VMs. I have only internal DNS and one public IP. And have ofc CMCM, IMP and CMS.
Can I setup MRA without External DNS ? (via public IP only without External DNS), if yes please guide me, all the configs I found on the net required external DNS server/domaine.
Can the setup be done with only one network interface on each expressway, since I don't have licenses (I intend working on evaluation mode just for test purposes)
Thanks in advance.
BR
01-15-2023 08:28 PM
New versions of expressway has no options keys for advanced features like dual Nic. So you can configure this without any licenses. For MRA you dont need any license features.
You dont need a public DNS, what you need is a DNS entries. If you have a public domain, the domain provide will help you to add DNS entries for your domain. Once added SRV will be available publicly.
Below mentioned are to be added on the public DNS
A record for expressway E this will be your public IP
SRV record
_collab-edge._tls.example.com SRV service location: priority = 3 weight = 7 port = 8443 svr hostname = vcse1.example.com
01-16-2023 05:38 AM
If you don't have external DNS, you can set up a PC to point to a router or something that has the DNS entries to find the Expressway-E. I did this in my classroom when teaching MRA deployment. Below are the DNS entries I had my student enter on a router. Then I had my students point the DNS of the PC to the router and flush the DNS cache. Obviously this would work for demo purposes only. You'd need public DNS (and public certs and such) for a production deployment:
ip domain-name externaldomain.com
ip domain-lookup
ip dns server
ip dns primary externaldomain.com soa <ip.of.the.router> administrator@externaldomain.com
ip host exp-hostname.externaldomain.com <ip.of.exp.e>
ip host _collab-edge._tls.extenraldomain.com srv 1 1 8443 exp-hostname.externaldomain.com
Maren
01-18-2023 11:42 PM
Mobile and Remote Access Ports
For MRA port information, go to the Cisco Expressway IP Port Usage Configuration Guide at Cisco Expressway Series Configuration Guides. The guide describes the ports that you can use between Expressway-C in the internal network, Expressway-E in the DMZ, and the public internet.
Network Infrastructure Requirements
IP Addresses
Assign separate IP addresses to the Expressway-C and the Expressway-E. Do not use a shared address for both elements, as the firewall cannot distinguish between them.
Network Domain
The ideal scenario for MRA is to have a single domain with a split DNS configuration, and this is the recommended approach. This is not always possible, so there are some other approaches to deal with various alternative scenarios.
