Fax problem on VG248
drobel
Hi All,
I have a strange fax problem. Usually this fax works well, but sometimes (2-4 a day) the other side gets an transmission error report, while my side receives the fax. Both Side have Canon faxes.
My side uses Vg248 with fax-passthorugh, receives the fax through a PRI , the other side uses Cisco 2600, with FXS module, BRI, and fax-passthrough.
can it be a configuration problem, or line noise?
On the incoming PRi gateway I use passthrough also.
The config:
dial-peer voice 103 voip
tone ringback alert-no-PI
description -=Kimeno FAX hivas CCM1 fele=-
translation-profile outgoing FAX-WAN
destination-pattern 5T
modem passthrough nse codec g711ulaw
voice-class codec 1
session target ipv4:10.223.248.10
fax-relay ecm disable
fax rate disable
ip qos dscp cs3 signaling
no vad
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice translation-rule 3
rule 1 /^5\(.*\)/ /\1/
voice translation-profile FAX-WAN
translate called 3
translation-rule 5
Rule 0 * 5
voice-port 1/0/1
no snmp trap link-status
translate called 5
cptone HU
timeouts call-disconnect 1
description ---=== FAX Kozponti ===---
station-id name FAX
station-id number 34849
BRI:
voice-port 1/1/0
translation-profile incoming Bejovo
compand-type a-law
cptone HU
VG248:
Call ID, mwi: off/none, no gain,
relay and ecm disabled, nsf 000000, passthrough automatic.
Bela
mmiktus
talk to TAC about this. there is a bug with certain IOS versions where a successful fax is delivered, but an error report is generated and sent back to the sender. This sometimes results in multiple faxes being transmitted to one side or the other.
Bug ID: CSCea65439
Bug Report: http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCea65439
my old service request number for reference:
604334959
