From CallHandler to Hunt Pilot->No Coverage Call Forward?
A User has forwarded to his voicemail. The Caller can dial 1, for leave a message, or 2 to forwarded to mobile. If the caller do not dial any option he will be forwarded to a the group of the voicemailbox-owner.
Caller A-->Caller B-->Voicemail-->CallHandler-->Hunt Pilot
I want to achive that if nobody anwsers in the group the call should be diverted again to the voicemail of caller B.
I am afraid that's not possible because the call is going from the callhandler to the huntpilot and not from phone B. So I could not define callforward no coverage.
Any ideas?
I am using CUCM-BE 8.6.1
Steffen
rsaborio
What is the current behavior with such forwarding. Do you get like the default greeting, or any other greeting?
The Call terminates when no line group member answers the call. I checked "use personal preference"
Sounds odd that the call terminates! As in just drops or do you get busy tone?
Would suggest a CSS issue to me!
Matty
No that's not odd. The call will be routed from the unity connection call handler to the hunt pilot.
If the call will forwarded from a phone to hunt pilot and nobody in the line group answers the calls I could say "use personal preferences" on the hunt pilot for forward on busy/no answer and it will choose the call forward no coverage from the originating phone.
If the call will transferd from the cuc call handler to the hunt pilot I could not select "use personal preferences" ( I could but it makes no sence) because the call handler has no callforward options for no coverage.
