02-26-2018 07:58 AM - edited 03-19-2019 01:10 PM
Hi Guys,
Hi Guys,
My Customer today have a Gateway H.323 with carrier X and will change for SIP with carrier Y. I know that in the CUCM side is need create SIP Trunk, change routes, and another things. My question is: in gateway what change need to do? Is possible SIP and H323 work in the same time, until that my Customer finish the contract with carrier X?
Wilson
Solved! Go to Solution.
02-26-2018 08:03 AM
Yes, H.323 and SIP can work at the same time. You will have to enable CUBE to your ISR and allow sip-to-sip connections. How do you currently connect to the ITSP? A PRI line or a H.323 trunk?
02-26-2018 12:35 PM
02-26-2018 08:03 AM
02-26-2018 09:05 AM
Hi Georgios,
Thanks a lot for Your contact. Today the H.323 is using E1 connection with the carrier. When You say "You will have to enable CUBE ", what command is used?
controller E1 0/1/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-30 type r2-digital r2-compelled ani
cas-custom 0
country brazil
metering
collect-call-enable
category 2
answer-signal group-b 1
Wilson
02-26-2018 09:08 AM
This is a good guide that explains the basics of CUBE: CUCM to CUBE Integration Configuration Example. You can start with that.
02-26-2018 09:08 AM
02-26-2018 10:32 AM
Hi Nipun,
Thanks a lot for Your contatct. Answering Your ask: My Customer will change H.323 to SIP and not more will be use the H323. But, I need test first SIP to see worked fine then cancel the H323 with carrier.
Wilson
02-26-2018 10:39 AM
I think you are confused a little bit here. As per your sayings, now you have:
CUCM - (H323) - VG - (PRI) - ITSP; i.e. your connection to the ITSP is ISDN PRI and not H323.
You want go to CUCM - (SIP) - VG - (SIP) - ITSP; for this you will need CUBE enabled at your VG.
02-26-2018 10:51 AM
02-26-2018 11:58 AM
02-26-2018 12:24 PM
02-26-2018 12:29 PM
Hi Nipun,
As I told previously my Customer need that H323 and SIP work in the same time. When SIP is validated the H323 will cancel with the Carrier. I have keep this configuration simultaneously.
Wilson
02-26-2018 12:35 PM
