04-28-2016 11:58 PM - edited 03-19-2019 11:03 AM
Hello all,
I have an issue about adding more than 9 alternate extension under one voicemail user. I now that, I can add up to 19 alternate extensions (9 Administrator Defined Alternate Extension, 10 User defined). But to add User Defined alternate extensions?
Best Regards
Bahlul
04-29-2016 01:13 AM
You will need to adjust Class of Service in order to allow this, refer below:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/user_mac/guide/8xcucmacx/8xcucmac050.html#wpxref90793
More details can be found at below good thread by Rob
https://supportforums.cisco.com/discussion/11458251/maximum-alternate-extensions
Deepak
04-29-2016 01:42 AM
04-29-2016 03:05 AM
I found it. I must login to PCA to add user defined alternate extensions.
http://<CUC IP>/ciscopca
Best Regards
Bahlul
