LUA logical and match
Paul Freiberg
Hi all,
I have that diversion string:
Diversion: " XXX" < sip:+4945131012091@172.22.1.101> ;reason=no-answer;privacy=off;screen=yes
Diversion: " XXX" < sip:+4945131012092@172.22.1.101> ;reason=deflection;privacy=off;screen=yes
Now I want to match on "+4945131012092" and "deflection":
if (string.match(diversion, "+4945131012092") and string.match(diversion, "deflection")) then
But it does not work, if I just match on on "+4945131012092" it works and if I just match on "deflection" it works too.
If I try to match on "+4945131012092@172.22.1.101> ;reason=deflection" it does not work too.
If I test it in Lua-5.1.5, it works.
Can anybody help me?
Nadeem Ahmed
can you please provide me your lua script and what is the CUCm version you are try to implement this?
Br,
Nadeem
Br, Nadeem Please rate all useful post.
I had a logical mistake in my scipt with:
I had to change it to:
elseif string.match(diversion, "+4945131012092",string.find(diversion, ",")) and string.match(diversion, "deflection",string.find(diversion, ",")) then
because I had the same syntax with -2091 before in the script.
After I debugged the script and found out that the sting is not a multiline string, it is separated by ",", I am matching just after the "," with combination of math and find.
The debug output is:
//SIPLua/Script/trace_output: Diversion is "XXX" <sip:+4945131012091@172.22.1.101>;reason=no-answer;privacy=off;screen=yes,"XXX" <sip:+4945131012092@172.22.1.101>;reason=deflection;privacy=off;screen=yes
So I found out that the RTMT output was filled with spaces.
Next time I will immediately debug the strings.
Regards and thanks 4 reading,
Paul
