How can I backup the speed dial of Assistant Console?
cmferreira
How can I do the backup of speed dials in Cisco Unified Callmanager Assistant Console?
I have a cluster running the version of CUCM 7.0.2.
Jaime Valencia
I believe this procedure is still valid
How to backup the Attendant Console speed dials or share them across multiple users in the Attendant Console Setup of the Cisco CallManager 3.x and Cisco CallManager 4.x
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K25073648
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
I'm finding that when I try to restore speed dials longer than nine digits, those entries are ignored.  I'm on CUCM 8.6.  Any ideas?
