how can i see if my unity connection is unrestriced or restricted version?
fgaeta
i need identify the correct versión, on both a CUCM 8.5 and CUC 8.5, because i need download the appropiate language or locale version to spanish latinamerican (colombian). There are some commando to see it? or how can i difference it.
Thanks for advanced.
Rob Huffman
Hi there,
The main gui access - the Help/show version - or the cli "show cuc version"
if you don't see the word unrestricted then you are running the Restricted version
Cheers!
Rob
Rob Huffman
Hi there,
Cheers!
Rob
Thanks Rob, now i'm sure that i have restricted version.
Best regars.
