12-03-2006 11:34 AM - edited 03-18-2019 06:40 PM
I tried by copying the subscriber template, and allow access to reset PIN.
Then assigned this to the subscriber, but if he logs in onto saweb, he gets this message;
Server.CreateObject(AvSaLocalization.AvSaLocalization.1) failed.
This is most likely an error with a DLL, probably AvSaLocalizationSvr.dll or perhaps AvSaLocaleInfoSvr.dll.
Check that these files are present, and registered with REGSVR32.
Also be sure that the appropriate MsgStoreRes.dll file is present.
Cannot continue.
(From: Global.asa: hr=0x80070005)
Is there a step I am missing?
it's Unity Voice Messaging 4.2.1 with ES47
on W2K3, and offbox Exchange 2K3 on W2K3
12-04-2006 07:48 AM
Sounds more like a problem loading resource strings for the language of the user's browser. What languages are installed on the system (Unity) and what language is the user's browser configured for?
12-04-2006 11:57 AM
US and NZ are installed, but only NZ is activated I think.
I'll check the browser, but am quite sure it's set to en-nz
03-20-2007 08:42 AM
I have the same issue. I checked the language on the browser(en-us) and it's correct, I restarted IIS and from the error message tried to register the dll file and I still the the error.
Any ideas??
05-13-2008 05:14 AM
we are having similar issues with Unity 5.01 did you find a fix?
