Hi David,
If the internal extension is configured as 123 then by dialing it internally as 123 it will not overlap with the translation patterns. When an external or internal user dials 5123 then the two TP's would come into picture, for a specific 5123 dialing the 5123 TP would be invoked and the Called Party Transformation Mask setting would decide what the final called party destination is. You also need to ensure that the CSS configured on the Translation pattern should have access to the partition of the final destination being called , else the call would fail ( like in this case the CSS configured on the TP should have access to Partition of 123 ).
Manish
- Do rate helpful posts -
