How to configure CUE 8.0?
yingwu
First of all want to upgrade license?thanks!
pid:SR-SRE-700-K9
show software   versions
Application eXtension Platform (AXP) version (1.5.2)
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Components:
- CommServer version  1.1
- Squid version  1.0
se-168-47-101-1# show software licenses
Installed license files:
- None
- None
Atul Khanna
you need to purchase licenses for CUE8.0
-Atul
Please rate, if this helps
Atul Khanna
-Atul
thanks !
I have update  FL-CUE-MBX-5,but not succeed,error this license  no match AXP feature
You are using the wrong license files.
