How to configure outgoing calls through multiple pstn lines?
Ihssan Alibouch
I have a Cisco CME runing on an ISR 2821 with 2 pstn lines setup for outgoing calls. I want to add the appropriate command lines so that the calls can be balanced between the 2 lines: outgoing calls should go once through the 1st line and once through the 2nd one
Can anyone help?
Thanks in advance
Ihssan
hi ihssan
hoping that you can use the hunt group to achieve that
like setting the preference in each one of the dial peer
With Regards
RAJASEKARAN R
"எங்கள் வாழ்வும் எங்கள் வளமும் மங்காத தமிழ் என்று சங்கே முழங்கு"
Jeffrey Ness
It would probably be better to define a trunk group (named POTS perhaps) and then on the voice-port configuration associate the ports to the trunkgroup in order of preference of their use (lowest numbers are most preferred) and then configure your outgoing POTS dialpeer to use the trunkgroup name you created.
