If i have a voip dial peer with destination pattern 4... and session target to a CUCM and have ephone-dn 10 with extension number 4000 configured on the same gateway.
If an incoming call comes into the DID for extension 4000 it sends the call to ephone-dn 10. I would like to setup the gateway so that incoming call for extension 4000 tries the voip DP first with pattern 4... and route the call to the CUCM First. If that call routing is not available then send call to ephone-dn 10
I have tried preference with no luck.
Any ideas
