How to restore UC Applications
scooter817
Level 2
Level 2
I wanted to know can someone point me in the direction of the instructions on how to do a restore of UC applications. We are currently moving all of our applications from our MCS server to UCS and I've never done a restore before. I don't know if this is possible but I want to know is there a way to pull down a copy of the restore I want and do the restore from my computer instead of the network.The reason I ask is because I want to keep the same IP address for my new box as my old box and I know you can t' have both on the network at the sametime because it will cause a conflict. Thanks in advance for any help and have a great day.
Jaime Valencia
It's the exact same thing, nothing is different, you use DRS, and you can have the backup in any tftp server you want.
Sent from Cisco Technical Support Android App
java
if this helps, please rate
Jaime Valencia
java
