i need to change extension number for fax device ata 190
Mahmoud0111
Dears ,,
i would like to change fax extension to be 215 instead of 1143
when some one outside calling us and enter Number 6 for fax it's transfer to extension 1143
i need it to be on 215 this number when outside calling us for fax enter 6  it's needed to be transferred to 215
thanks in advanced
6 Replies 6
Mahmoud0111
can i change the Directory numbers digits to 3 number instead of 4 mgogna
can u advice me on this one
The directory number can be changed, you just need to make sure that the call routing is setup correctly on gateway and cucm to be able to reach this 3 digit extension.
Manish
mgogna  please can u tell me the steps because when i create a directory number for my ata 190  it's can't be reached from outside but only from inside
mgogna  can you help me with this case please with steps how to do it !
i have cucm system version 10.5
i have all ip phones with 4 digits extension
i need to create 1 extension for fax so it will be 3 digits so i can get calls on fax from outside with this 3 extensions
i want to know how to do it on my cucm
thanks in advance
If the Fax server is integrated via  a SIP trunk to cucm then configure a Route pattern on cucm with three digits and use the SIP trunk pointing to fax server in the route list.
Manish
it's configured as sip but i don't know if it's configured as sip trunk or no
check the screenshots on the attachments
