Implementation plan
Trying tobeone
Hi Experts,
Our customer have ordered for the products which are given in the attached file. But they are not having any project plan and while checking i came to know that some softwares like UCCX and IME are coming free along with the UWL licensing.
They are plannign to deploy these products on 4 UCS servers, with 2 server in DC and 2 servers in DR.
Could anyone please tell me how to plan on which all products to be installed on per server basis. And which all license to be generated and where to upload it like on Pub or Sub??
Any help will be really appreciable.
Thanks in advance
Jaime Valencia
Licenses for CUCM need to be tied to the LICENSE MAC of the PUB.
If you're new to UC on UCS I strongly suggest you to review the virtualization wiki and then come back with any doubts you still have
Unified Communications  Virtualization Sizing Guidelines
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization_Sizing_Guidelines
Unified Communications in a  Virtualized Environment
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Java,
Thanks for the reply.
I have previously worked on UCS C series server. But here am confused because am not having any implementation plan.
My main doubt is as per licensing how many servers can be installed for the Products,
1, CUCM
2, CUPS
3, Unity Connection
Also which all products has to be installed on per server basis, like there are 4 UCS servers, so how can i design and plan for the coresidency of these products on per server.
If you can throw some light on this even breifly also, it will be really helpful.
