11-05-2016 04:38 AM - edited 03-19-2019 11:47 AM
Dear All
I am trying to install cucm v 11.5 , but I stuck in NTP setting , I cant bypass this setting. I try many way but I couldn't success , any guide line from your side.
Thanks in advance.
Nasir Aziz
Solved! Go to Solution.
11-05-2016 09:48 PM
You can configure NTP as follows on a router/switch:
router # configure terminal
router(conf) # ntp master 1
* This will set the IOS router/switch as your NTP master with stratum level 1.
* You can check the local clock for the router using the following command:
router # show clock
* You can set clock using the following command:
router # clock set hh:mm:ss
While performing addition in CUCM setup, just enter the NTP address of the router/switch you just made as the ntp master and CUCM should be able to proceed fine with the installation.
11-05-2016 06:14 AM
You need proper stratum level NTP in order to install CUCM. If your CUCM has internet connection and you do not have internal NTP then point to public NTP which you could locate:
http://www.pool.ntp.org/en/
11-05-2016 09:01 PM
Chris , can you explain me more , this is first time for me , or give me example and steps.
11-05-2016 09:48 PM
router # show clock
11-05-2016 09:56 PM
Thanks Sood, I will do necessary now and feed you back
11-05-2016 07:48 AM
Best would be to configure an IOS based NTP. Since you are installing cucm in lab you can also use another cucm or cuc server as an NTP server.
Aseem
11-05-2016 08:57 PM
Thanks Aseem for your reply , can you give me example , because this is first time for me to configure CUCM
