Installing Unity using ILO
degg
I know you are not supposed to install Call Manager using ILO, but I cant find anything that says you shouldnt use ILO when installing Unity.
Is using ILO for installing/upgrading Unity allowed? Has anyone ever done it? Version 4.0(4).
Thank you!
Tommer Catlin
Probably not with 4.0(4).... there are two many complicated steps involved. Possibly in the newer versions it may work.
The following out-of-band management cards are supported for use with Cisco Unity 4.2 and later:
?Dell Remote Assistant Card, version 2.0.
?Hewlett-Packard Integrated Lights Out (iLO).
?Hewlett-Packard Remote Insight Lights-Out Edition, all versions.
?IBM Remote Supervisor Adapter II, all versions.
CallManager is a different horse... you can autoinstall that pretty much.... but Unity involves AD, SQl, Exchange and all sorts of "stuff" that involve a monkey hitting key strokes and following instructions for installation.... flying monkey? possibly.
hope this helps
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_system_requirements_hardware09186a008061eab9.html
