Integrate Microsoft System Center 2019 with CUCM 14.x
Alex Ribas
Hi all
Someone tried Integrate Microsoft System Center with CUCM?
I appreciate your help.
Alex
No, CUCM doesn't allow you to install anything on the OS and you don't have a way to configure scripts/powershell to run on CUCM.
If there's any way to integrate them, it's not going to be anything native on the CUCM side and you'd need something in between to do this, which you might need to develop yourself.
java
if this helps, please rate
Jaime Valencia
Exactly what kind of integration are you talking about?
java
CUCM 14.x or 12.x <-->  (Cireson https://cireson.com/blog/4-ways-to-integrate-applications-with-service-manager/ (Front End ) already installed in  Microsoft System Center 2019
java
Thank you @Jaime Valencia I appreciate your help.
Cheers
Alex
