integration CME 8.6 with 2N IP Helios SIP Door Phone
zakid
Good Day,
I have a Cisco CME install on router 2911 with CME version 8.6 and i need to have any boday do the integration between CME 8.6 and SiP door intercome
my SIP door Intercome is 2N IP Helios Door Phone With 6 button , i already did integration before but with CME it was  with cisco call manager business edition by create end user and integrate the user with the system and add that user in hunt group for particular phone how should ring...... any way if any boday have help in the same issue please give me ASAP.
Thanks.
7 Replies 7
carlos_canepa_2
Hi Zakid, i have the same scenario, cme and 2n helios ip.
It works for voice, but does not work for for video.
Video is not transmited.
I had 8941 phones, adn video working between them.
The same here.
Works for voice, but no video!!!
I'm still working on it, and let you know in case of any progress.
did you manage to get this working
i have video and audio working but cannot get the door to release from IPPhone.
Did you manage to get the door release working from 9951 to 2N Helios Door system.
can you share some configuration.
shameer
Hi Fareed,
Yeah, it's working.
I'm gonna post my config here in a while.
Hi Leandro
Good to hear you got it working. looking forward to your config
Also please let me know how you get the IPphone to release the Door as well.
regards
shameer
Can anyone share the step by step instructions to configure the 2N video doorphone so it works with a UC540 (CME)?
I have not been able to find any instructions, even though there is that great video showing how well it works.
Please, post your config - the same problem(((
