Interface Network Verification failed
Hary_CsC
Level 2
Level 2
Haii
Please help
Yesterday I accidentally changed Static to DHCP Server on cusm, after Restart.
can't be opened and after checking on the VM by console there (attach)
"Network Verification failed"
I want to it static again, please advise and solution.
Thx
You made it dhcp, so connect a dhcp server to get the Ip. Once CUSM gets the IP u can convert it to static.
Response Signature
5 Replies 5
Your best option is to call TAC and open a P1 SR.
Response Signature
Haii Kallberg
Was there no solution before "open tac"?
Thx
If the CUCM server vlan doesn't have a DHCP server, configure one and on vlan  interface   configure IP helper address as the DHCP server. The server should take an IP address from the DHCP.
Response Signature
Haii Nithin
This is CUSM, and I want to make it static. but CUSM cannot be accessed and the VM appears a notification "Network Verification failed"
Thx
Response Signature
