IP Communicator 7.0 - device name parameter storage location
mherges25
I'm interested in figuring out where the "FREEFORMDEVICENAME" mentioned in the Admin Guide would be stored?  I've setup my Communicator users with device names is CCM that are the same as their usernames for Active Directory.  I was hoping to be able to run a script of some sort to populate a key or file with a device name by using the windows %username% variable.  The only info I can find in the Admin Guide is for command line parameters. As of yet I can't find where on the computer this variable/setting is stored....  Any help would be appreciated.
0 Replies 0
