IP Communicator and EM Logout Problem
KY_
Level 4
Level 4
Hi Everyone,
we want to logout our client when They close ip communicator, is there a anyway about this ?
All agent forget logout after complated their shift and  another agent can not loginn the same computer,
How can I  do logout  closing agent ip communicator  ?
Jaime Valencia
There is no native method to do so.
You can try to set the maximum login time so they're logged automatically.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
How can I set maximum loggin time ?
Under EM service parameters
java
java
