IP Communicator default http port - can it be modified?
Chris Tolley
Level 3
Level 3
When running the CIPC (IP Communicator) client (version 7.0.3.0), the device information for the client is available by http port 80 at the ip address of the pc the client is running on (in the same fashion as the ip phones). However we have need to reserve this address for an in house requirement.
Is it possible to modify the port the IP Communicator responds to http request?
6 Replies 6
William Bell
Last time I looked into this I found that you could disable the HTTP server on CIPC but you could not change the port.  The process for disabling was captured in a release note I believe.  Also captured in this netpro doc:
https://supportforums.cisco.com/docs/DOC-3820
I checked the CIPC 7.0 release notes and I do not see mention of any new features which would allow port customization.
Sorry to say, it looks like your choices are to disable it or use TCP 80.
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
That will work. We don't use the local web port much.
Thanks!
Unfortunatly it does not work on my client (7.0.3 on Windows 7). However the procedure comes from the 1.2 release notes. I did not see anything about this in the 7.x release notes. Perhaps this "feature" is no longer available.
A model-specific option has been added within the device configuration page on UCM to control this. I'm not sure exactly what version; this is probably what has caused the registry manipulation workaround to stop functioning.
Found the entry under CUCM Administration>Device>Phone>Product Specific Configuration Layout>Web Access
Disabled, applied and reset and I can no longer get to my CIPC device via http port 80. I've set the user in question up with this so hopefully this will resolve.
Thanks all for the help!
Tank you very much!
Additionally you can check what port is being used through the netstat -ab command in Windows:
C:\Windows\system32>netstat -ab
Active Connections
Proto Local Address Foreign Address State
TCP 0.0.0.0:80 DESKTOP-BQECTRT:0 LISTENING
[communicatork9.exe]
