IP of CUCM not showing up
inaeemcisco
I have installed CUCM as a virtual machine via VMware ESXi server and when I access server through Vsphere client application it does not show up "IP address of CUCM VM", and an Error occurs in "Console". Picture of error is attached need guidance
Deepak Rawat
Looking at the screenshot, the File System seems to be corrupted. Can you try to run the Recovery Disk as per the below link:
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118948-technote-cucm-00.html
Deepak
- Rate Helpful Posts -
