Assuming you're using the same network information, you cannot have the same info in two servers at the same time, you'd need to keep the new servers disconnected, wait for the old server to shutdown, and then connect the new servers.
Assuming all the network info and ITL is the same, yes, they should start registering.
java
if this helps, please rate
